DISPOSAL: pegaso Models
COLOURS
ANDREA, VALLEJO, CITADEL
he figure consists of just 3 pieces of metal. 4 with the very simple basis that came with it and not used
Dot etching. Splurge Very clean with minimal production line
PREPARATION:
Unchecked pieces of the figure and began immediately after the cleaning of the few production lines. Originally cutter and then with various degrees of 3M.
Then in the settled habits washed with warm water and dish soap and using a hard brush apomakrinthikan residues resulting from the above work.
When dried glued the pieces and run with plastic grey Primmer
PAINTING :
SKIN: painted with Andrea colour set for the emergence of hairs which were embossed used various transparent brown and black of companies citadel and vallejo
Rise to the vignette was given from the following photo...............
The man in the sketch from left is saying to the other: "pulls the hair .......... otherwise you will FILLED sand and will not boreiss to fuck her!!" hahahhahaahahhahahhahahah
The lady who drags our friend ...... Consists of 8 bit different stunts and stucco. Putty also created the ewe and hair putty Added
Finally tusks are from dental putty
thanks
